HELP PLEASE! Fuse issues 85 w150
Old Jan 22, 2013 | 12:43 AM
1b2t3a's Avatar
1b2t3a
New Member
Question HELP PLEASE! Fuse issues 85 w150
Hey guys, I have a 85 w150 I recently added a voltage guage and pulled the ac clutch fuse beause I dont have ac, anyways I tapped the gauge into that fuse and since then my gas gauge doesnt work and when I turn on the lights my right turn signal indicator stays lit. Please help thanks
Old Jan 22, 2013 | 12:52 AM
crazzywolfie's Avatar
crazzywolfie
you might have knocked something when loose or something when you installed the voltage gauge. did you check the front right turn signal light to make sure it's not out?
Old Jan 22, 2013 | 11:53 PM
1b2t3a's Avatar
1b2t3a
New Member
I will have to check, thank you. Anymore ideas anyone?
Old Jan 23, 2013 | 12:00 AM
crazzywolfie
no. the gas gauge not working but the rest of the gauges working could be a bad ground problem. the dash turn signal lights are tied into the front turn signal lights and i think if one quit working the light will come on and stay on like you have.
1b2t3a's Avatar
1b2t3a
New Member
Do you think pulling the ac clutch fuse caused anything? I dont have ac
Old Jan 23, 2013 | 12:02 AM
crazzywolfie
as far as i know the a/c fuse has nothing to do with those things. gas gauge gets its power from the same place as the temp and oil pressure gauge.
Old Jan 29, 2013 | 11:00 PM
1b2t3a's Avatar
1b2t3a
New Member
Ok, thanks. I dont even know why they out ac clutch fuses in a truck with no ac haha
Old Jan 29, 2013 | 11:09 PM
crazzywolfie
maybe the truck had a/c at one point in time. the trucks that have don't have a/c will have a power wire in the a/c fuse hold but that is it.
Old Jan 30, 2013 | 08:30 PM
Cameron1997's Avatar
Cameron1997
not quite sure if this is really even relevant but could you have a burned out running or turn signal light on the right side? that happened to me before when my running light was bad.
