Interchangable driveshafts?
Old Feb 3, 2013 | 07:11 PM
MNfarmboy's Avatar
MNfarmboy
Default Interchangable driveshafts?
So long story short this weekend i got stuck while driving over snow piles. After i finally got out i noticed serious vibration starting at 20mph. I looked around under the truck today and noticed a sizable dent in the rear drive shaft. I would prefer to get one from a junk yard, rather than spending a lot of $$$ on a new one. I am wondering which models/years are compatible with my truck. I read the gen2 short bed club cab is close, but not sure if that is true. Any input is appreciated. Truck is a 91 w150 long bed automatic with 318
Posted from Dodgeforum.com App for Android
Old Feb 3, 2013 | 09:10 PM
crazzywolfie's Avatar
crazzywolfie
get a measuring tape and measure your drive shaft then go hit the junkyard with the measuring tape. if you your truck has overdrive then a driveshaft out of a regular cab long bed might work. if your truck does not have overdrive you may need to check short bed club cab. this is why measuring with a measuring tape is so important.
Old Feb 3, 2013 | 09:42 PM
MNfarmboy's Avatar
MNfarmboy
My truck doors have overdrive, hopefully I'll have time tomorrow to measure. Doors anyone happen to know what the length of a regular cab long bed drive shaft is, if not I'm sure it can't be to hard to research
Old Feb 4, 2013 | 06:33 AM
sls001's Avatar
sls001
You also need to be certain it has the correct u-joints besides the length being correct.
Check for local drive shaft shops in your area or a machine shop that does DS work
You can also use the site below to see what might be available near you.
www.car-part.com
Old Feb 4, 2013 | 09:11 PM
MNfarmboy's Avatar
MNfarmboy
Well, i used carpart.com (which i have been on before, but never actually used) and found a grade A drive shaft for $75, i ordered it and hopefully it should be here around the end of the week. I figure i might as well replace the u joints while I'm at it. Now all that's left is to install it in below freezing temp on my driveway, that should be a lot of fun. Thanks for the help
Old Feb 5, 2013 | 06:04 AM
sls001's Avatar
sls001
I've used www.car-part.com a number of times and have had very good luck.
My point on the drive shaft u-joints is your truck is a 1/2 ton with most likely 133L type u-joints, a 1-ton or 3/4 ton with 4,500lb front axle could the same wheel base but have 1410 series u-joints which would require you to replace the yokes on the transfer case and rear axle or get the correct shaft due to their physical size.
Old Feb 5, 2013 | 07:55 AM
MNfarmboy's Avatar
MNfarmboy
Well, they told me it was coming off a 90 w150, so in theory it should be the right u joints, but i will make sure to check that before i try to install it. Thanks for the info
