Bulkhead
Old Feb 13, 2013 | 07:59 PM
Longboy440's Avatar
Longboy440
Default Bulkhead
I could reall use a wiring diagram fo an 81 dodge ram. I have an 88 Ramcharger I dropped a 440 in and got alot of it figured ou just need info on the wiring!!!! Thank you
Old Feb 13, 2013 | 08:03 PM
crazzywolfie's Avatar
crazzywolfie
so your trying to figure out what wires in the bulkhead connector do what? are you trying to find something for a a 81 or 87? there is a difference.
Old Feb 13, 2013 | 08:11 PM
wontacceptthis's Avatar
wontacceptthis
The motor is probably an 81, so he probably needs the wiring for an 81 with a 440. I think.
Old Feb 13, 2013 | 08:16 PM
crazzywolfie
no 81 ever came with a 440. someone would have had to install it. without more details that we can understand can't really help. only advise would be buy a service manual for the truck you are trying to fix.
Old Feb 16, 2013 | 10:30 PM
moe7404's Avatar
moe7404
the last year for a 440 was 1978. i had a 82 ram i put 360 in that came with a 318. the 82 had bolt holes for a 440 in the fame.
Old Feb 17, 2013 | 06:24 PM
Longboy440's Avatar
Longboy440
Sorry about the confusion! I have an 88 Ramcharger that I pulled the 318 efi, and dropped a 440 in. I got a wiring harness from an 81 ram . I just need a wiring diagram for the 81 . The rest I can figure out .
Any other info or past experience with a engine swap is welcome thank you kindly.
Old Feb 17, 2013 | 06:43 PM
crazzywolfie
the bulk head connector on a 81 is different than the bulkhead connector on a 88.
this is for a 87 but should be almost the same as 88
Old Feb 18, 2013 | 08:08 AM
Longboy440's Avatar
Longboy440
thank you just what i needed
