Ticking when truck starts
The seals that I put in were valve seals. I use Castrol oil in all my vehicles and I am going to run a little bit of SeaFoam in the oil for awhile and then change out the leaking rear main and put in a new oil pump with lighter weight oil.
If the mods change your username, do all of the threads and posts change as well? Old threads have new name? Not that I have a ton of stuff, but I like it here and dont really want to start over. Lol
To the OP - Sorry for the mini-hijack.
I do believe you are looking at a sticking lifter. It may be gummed up, so it takes a moment for the oil pressure to build enough to get it moving like it should.
I do believe you are looking at a sticking lifter. It may be gummed up, so it takes a moment for the oil pressure to build enough to get it moving like it should.I had to re-register as a newbie.
nothing carried over.
