Donor Truck????
Old Feb 19, 2013 | 11:53 AM
crazzywolfie's Avatar
crazzywolfie
how comfortable are you with wiring? i think you may have to do a bit of wiring under the hood to make it work but essentially you will have everything you need if you buy a 92-95 donor truck with a magnum engine already in it.
Old Feb 19, 2013 | 04:14 PM
MNfarmboy's Avatar
MNfarmboy
I have never been a fan of wiring, but as long as its not too complex i think i would be able to handle it. I think what i will do is keep the magnum and replace later if I need or decide I want it. A question for eric.b, how hard was mounting the master cylinder and running the hydro lines, if that is not to bad then i think im alright because Im guessing the pedal swap and master cylinder will be the hardest part. Thanks for all the help so far
Old Feb 19, 2013 | 07:55 PM
ghonhee's Avatar
ghonhee
There's quite a bit on ramcharger about the magnum swap.
Old Feb 20, 2013 | 10:21 AM
MNfarmboy's Avatar
MNfarmboy
Ive decided that for the time being I'm not going to do the magnum swap, still trying to decide if i will keep the motor for later, i guess that I will decide that by determining how much money i want to recuperate. Anyone got any more tips for me?
Old Feb 20, 2013 | 11:18 AM
crazzywolfie
well if you take the engine, under the hood wiring harness/computer and transmission you still might get $500 for what is left. someone may need axles or something that is left is left and willing to pay $500 which is way cheaper than having axles rebuilt. if you decide not to do the magnum swap in the future you could probably sell the engine with the computer wiring harness for an easy $200.
