Odometer
Odometer
Well after years of having the odometer not working I decided to get new gears and fix it. I also wanted to remove the blue green bulb covers to make the dash brighter. I had changed out the dash to white gauges and it helped but it was still to dark. Everything came apart like clockwork and it was easy to do. I went ahead and pulled the bulb covers out and decided to replace a few of the bulbs that didn't look good. Put the gauges in the truck and plugged them up and the left half of the lights didn't work. I pulled the bulbs out and found the the contacts were not good. I made sure that the little wires were in the right spot and everything now works. It sure is nice having the odometer work and the white lights with the white gauges it is much brighter and easier to see.
I googled odometer gear replacement and found a you tube video. Mine had four screws holding the clear plastic back which I removed and allowed me to get to the two screws on the side where the motor is. The circuit board slipped out and it was easy after that. My small gears was missing several teeth and a couple where attached to the large gear. I was a little nervous about tearing into the speedometer but it was rather easy. Some one had a good write up with pictures that I found a few months ago but I could not find it again. The you tube video did help. I took a picture of the dash with the without the blue green bulb covers tonight and will try and post them tomorrow. I am not real computer savy and will get some help tomorrow.
Trending Topics
Where did you get the new gears? My 86 D-150 odometer works fine but my 90 D-150 is TU and I need to fix it. I am also curious about the LED light change over, my dash lights work but are dim like most and about the only mod I have done to date is take the bulb out of the stupid Main Req slot.
changing to led's is easy. just have to make sure you got the sockets that you can actually replace the bulbs in. i know my 91 had the lights soldered to the sockets and it would be easier and cheaper to replace the sockets than to make it work with led lights. i think the biggest and hardest thing is choosing the right led lights. i like the inverted led lights a lot more than the focused led's i original ordered for my truck.
