1989 power ram with wrong motor?
Old Apr 3, 2013 | 07:49 PM
Lambiotte's Avatar
Lambiotte
Default 1989 power ram with wrong motor?
So I just took possession of my day's aging power ram. According to what I can find, it should be fuel injected, but it is running a nice little Holley 2 bbl. the vac diagram on the hood shows a throttle body, and I have über vacuum issues.
Should I be seeking a diagram from maybe an 88 or earlier?
Anybody got one????
Thanks
Charlie
Old Apr 3, 2013 | 07:52 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
89 would have TBI, so it's possible the vacuum diagram would look like a TB.
Your truck may have been converted to carb at one point? IDK.
Old Apr 3, 2013 | 08:09 PM
Lambiotte's Avatar
Lambiotte
Exactly what I thought, do you know when they stopped coming equipped with the 2bbl or where I could get a vac diagram?
Old Apr 3, 2013 | 08:25 PM
crazzywolfie's Avatar
crazzywolfie
holley also made throttle bodies for the TBI and they looked very similar to the 2 bbl carbs. this is most likely what you have sitting under the air filter
Old Apr 3, 2013 | 08:54 PM
Lambiotte's Avatar
Lambiotte
You are the man....that is exactly what I have sitting under the air cleaner....so that makes the vacuum diagram on the hood accurate.
How does one service the throttle body?
Old Apr 3, 2013 | 09:17 PM
crazzywolfie
the diagram on the hood would be correct.
if fixing any vacuum leaks solves any issues you are having then i would not touch the throttle body.
Old Apr 3, 2013 | 10:03 PM
Lambiotte's Avatar
Lambiotte
Thanks
