extremely annoying metallic squeak
Old Apr 23, 2013 | 07:05 PM
Comrade General's Avatar
Comrade General
Default extremely annoying metallic squeak
So I have this terriblebly annoying squeaking noise on my truck. Idk what it is. I though it was my rear break getting worn out but took it to les shawb and they said the rears were fine. The front breaks are brand new. Its squeaks all the time especially after Ive been driving a little bit. Its driving me crazy. I thought it might be the front breaks breaking in but its been a month.
its like squeak...squeak...squeak like a rotating something. When I brake it becomes more of a constant squeak.
Im about ready to swap break pads to try and fix this, but could it be something else? Bearings or something possibly but it shouldnt be them either.
Old Apr 23, 2013 | 07:24 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Front u-joints or hubs are the first things that come to mind for me.
Old Apr 23, 2013 | 11:39 PM
Comrade General
That crossed my mind too but why would the noise change when i apply my brake?
Idk if this helps but sometimes when i turn a little the squeak will go away and then come back when I straighten up
Old Apr 23, 2013 | 11:47 PM
dodge dude94
That still tells me hubs or u-joints.
Old Apr 24, 2013 | 05:36 PM
Comrade General
what would be the best way to determine for sure? Jack it up and turn everything by hand?
Old Apr 24, 2013 | 06:18 PM
dodge dude94
Yep.
That's the only way I know of.
Old Apr 24, 2013 | 06:19 PM
Comrade General
Ok. thanks
Old Apr 26, 2013 | 06:31 PM
Sniper X's Avatar
Sniper X
For sure jack up the entire truck if you can and rotate each wheel independently. It sounds like a part in the front BRAKES to me.
Old Apr 26, 2013 | 07:50 PM
wontacceptthis's Avatar
wontacceptthis
FYI my rear u-joint was bad a few weeks ago but didn't make any noise unless the driveshaft angle was being changed by acceleration. Doing a brake torque and slowly rolling forward made the thing scream. Coasting it didn't make much noise until I beat the @#%& out of it trying to positively diagnose it.
Old Apr 26, 2013 | 10:54 PM
Comrade General
I was just doing soms stroker research and I came accross a thread that was talking about shimming axles when a lift is applied. I noticed after I got my lift I had shims on the front axle (cant remember if there were any on the rear but I don think so) but since my axle swap I dont have them installed anymore. Is it possible my axle(s) need to be shimmed? And could that cause the squeak?
