about to pick up a d150 need some answers
Old May 3, 2013 | 03:29 PM
  #61
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Originally Posted by Turner661
yea there fixing everything im pretty stoked about it. and also what do you mean exacly if i find a 14x3 enclosed housing with hoses is there a picture of someone whos done that just so i can visually understand?
14x3 is a generic name for an old school open element filter housing that accepts a filter that is 14 in in diameter by 3 in tall. Benefit: it looks cool and with proper venting, is good for performance.
There are some aftermarket 14x3 housings out there that are closed housings, but have hoses running out from the housing, usually meant to go to the grille to pull in cool air.
And no, I do not have a picture off hand.
Old May 3, 2013 | 03:34 PM
  #62
Turner661's Avatar
Turner661
hey i just saw this in a off road website would this work or probably be really restrictive
Old May 3, 2013 | 04:01 PM
  #63
dodge dude94
^Link no worky?
Old May 4, 2013 | 12:05 AM
  #64
Turner661's Avatar
Turner661
hey so i picked it up drove like a truck but after my 10 min drive highway and all i parked it and once i parked it it started to leak coolant from the knozzle. it has been parked for a while maybe thats why? or what cause it to get hot so quick? the tempature gauge was right in the middle were all my vehicles usually sit so it should be leaking coolant. my friend said on his car it was parked for a bit and the first drive it over heated and leaked coolant but hasnt really since
Old May 4, 2013 | 08:06 PM
  #65
wontacceptthis's Avatar
wontacceptthis
What are you referring to as a "knozzle"? From my experience, these trucks heat up pretty quick. Mine will get up to operating temperature pretty quickly.
If it's leaking, there really aren't many options as to what it could be.
A. Bad hose
B. Loose clamp
C. Leaking water pump
D. Stuck thermostat causing blockage
E. Blockage in the heater core or radiator.
Old May 4, 2013 | 08:09 PM
  #66
sls001's Avatar
sls001
Are you talking about the overflow tube at the filler neck?
If so you should have an overflow bottle.
and what is a "knozzle"
Old May 4, 2013 | 08:15 PM
  #67
wontacceptthis
Oh, also, that motor is not a 400. That's a small block, so it's either a 318, or 360.
. . . unless of course there are optical illusions being played, and the distributor is just resting on the wrong end of the motor.
Old May 4, 2013 | 08:36 PM
  #68
sls001's Avatar
sls001
If your talking about the images 1 page back (the underhood shot of the air cleaner) I don't think that is a picture of the truck he bought; he was asking about the air cleaner and hose assembly; wanting to find one.
The images from the first page are of a big block truck.
Old May 4, 2013 | 08:45 PM
  #69
wontacceptthis
AH-HA!!!! My bad. Thanks for pointing that out so nobody got confused.
Old May 5, 2013 | 09:24 AM
  #70
Turner661's Avatar
Turner661
so it first sprayed out of the cap that says dont not remove when hot so i got a new one of those and then it was fixed then started to gurgle and sprayed out of my over flow.. but the engine gauge said it was right in the middle of being hot were most vehicles usually are at
