Water on driver side floor
Old May 7, 2020 | 03:46 PM
Squirrel130750's Avatar
Squirrel130750
Default Water on driver side dilemma
Originally Posted by Cameron1997
I've had this problem for a while now and i finally decided i need a little help.
I recently noticed their is water under my floor mat (no carpet aftermarket plastic flooring) after I drive in wet conditions and I'm not positive where it is coming from but I believe it is the kick panel vent. Originally I believed it was coming from where the parking brake comes in but i sealed it shut with caulking and still have the problem. So if it is the kick panel vent could a person take the front fender off and rtv around the whole thing? Let me know if its happened to you and if so how you fixed it, thanks for looking!
. Had to remove front inner fender. Cut hole in A pillar at very bottom. Scooped a large pike of foam that Dodge had filled the cavity with. Great for noise but not so for water to get to drain holes. Re welded piece in and water problem inside gone.
