loose tilt steering wheel 1988 D-150
Old May 24, 2013 | 11:29 AM
buubakitty's Avatar
buubakitty
Default loose tilt steering wheel 1988 D-150
need help
Old May 24, 2013 | 03:51 PM
Sniper X's Avatar
Sniper X
Just a guess but do you mean the tilt mart is loose? If so the mechanism is probably worn which is why I personally never really liked tilt steering.
Old May 24, 2013 | 05:10 PM
sls001's Avatar
sls001
If it is the tilt-part it is a simple matter of removing the upper section of the column, tightening 4 screws (Torx) and re-assemble it.
Old May 26, 2013 | 05:39 PM
firefish's Avatar
firefish
I recommend that you get a tool for removing the steering lock plate/bearing spring preload retainer - I managed without but it wasnt funny. Get a steering wheel puller too. You'll only be able to tighten the two lower screws without ripping the entire column apart but that has been enough for me.
If you google tilt steering column fix you'll find a guide at a chevy forum (our columns are GM) with pics. Its not tricky, will take you about an hour.
My bolts werent torx but some other kind but the forum how-to stated which one and it was correct for me.
