Engine preformance ideas?
okay thanks sniper x. I have decided on a magnum swap, I just have to find the engine and components now. Currently though i am working at getting my truck cleaned up while i still work at a body shop so the swap will have to wait till next summer which i guess does give me time to find what i need. Thanks everyone for the info! Its what i needed to know.
If I wanted more power I would just do a cam, headers, carb, intake, and 340 race heads. Possibly even aftermarket pistons. You can find good 318 or 360 builder motors on the local Cl for peanuts and build them to full potential then swap them out in a weekend. Shoot, you can build a 318/340 to well over 300hp easily and that would rock in a truck. Sure you could not pass smog, but no one who has to does this anyway.
thats all i was going to do for swapping a magnum into mine, was just using the harness under the hood. I've actually found something better than a magnum that I'm working at getting my hands on right now, a 4bt cummins that looks new and has been sitting the past couple years. I have experience with the 12v first gen cummins since i use to own one so i am trying real hard to get this engine
im having the same restiction problems on my 91 d250, im wanting about 100 more horse before you could just add a cam, mill the head 10 to up the comp ratio, good aluminum intake, big tube headers and a free flow aircleaner and you had it, im going to try it with my 91 its has a little advantage tho it has a 4 speed automatic with 4;11 in the rear im going to try a little above an rv cam, headers, maybe a streetmaster intake with the tbi adapter ill try to keep you posted if it works ok it a couple months down the road project
