D150 s6/904 to 440/727 swop
Old 08-04-2013 | 01:54 PM
glennmlb's Avatar
glennmlb
Default D150 s6/904 to 440/727 swop
Did a lot of searching. But here goes my Dlima. Bought an 1978 RV 440/727trans, yoke drive. Its replacing a 1987 slant6/904 spline drive. The 727 rv tranny is much shorter. Has anyone gone thru this before?
Old 08-04-2013 | 07:22 PM
sls001's Avatar
sls001
? Gone through what exactly? Are you talking about the drive shaft not being the correct length? The cross-member in the wrong place? More details please.
You can get a drive shaft made easy enough.
Old 08-04-2013 | 08:52 PM
glennmlb's Avatar
glennmlb
Thanks sls001 for the reply. Forgive some of my spelling errors "swop". Just finish pulling the s6. And I do not have a clue on attaching the tranny. Motor mounts should be avilable from my online research. I will need vacuum and electrical diagram. That I thing I can find online too.
Old 08-04-2013 | 08:58 PM
crazzywolfie's Avatar
crazzywolfie
so did the slant 6 have the lean burn system? i don't understand why would need a vacuum diagram. there is not that much to hook up.
Old 08-04-2013 | 09:35 PM
glennmlb's Avatar
glennmlb
The s6 came out since it had a hole in the block. Already had a 440/727RV combo. I am a fluid power mechanic and not an auto mechanic. Vacuum for brakes, timing advance, and maybe tranny shifting. I am all open to learning from those who are helpful.
Old 08-11-2013 | 12:24 PM
Scooter78's Avatar
Scooter78
I don't think your electrical system will be much different, if at all, between the two. You still only have a starter, coil, and alternator. Three wires will start that engine. Being as neither one of your transmissions are electronically controlled, that wont be an issue either. If you found conversion engine mounts, you may want to buy them, unless you are handy with a welder. Also, I believe the trans mounts are in a different spot. I think the easiest way to fix that is to move the trans crossmember. Its just held in with a couple bolts on each side. Unbolt it, bolt it to the trans, then use the bolt holes in the crossmember as a template to mark new holes to poke in your frame. Then bolt her up. You will likely need to have a custom driveshaft made. That can usually be done for under $200.
