Steering Coupler Roll Pin
Old Sep 18, 2013 | 09:27 PM
wontacceptthis's Avatar
wontacceptthis
Default Steering Coupler Roll Pin
I'm doing the infamous steering shaft coupler repair. Actually, I've got the truck back together now since I couldn't even get anywhere.
How do you get the stupid roll pin out that holds the coupler to the steering box? I got the nylon inner pin out, but the roll pin itself isn't budging. I've been trying to get it out with various improvised punches and a stubby sledge. It hasn't budged. I don't really know if I can use heat on that. There is grease all through the coupler, and I'm afraid it would heat up the steering box as well.
To anyone who has done the repair, how did you get the roll pin out?
Old Sep 18, 2013 | 09:28 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
I am interested in this as well, and when you get it done, I'd love to hear your feedback on it.
Old Sep 18, 2013 | 11:58 PM
crazzywolfie's Avatar
crazzywolfie
i think heat might be one of the only ways to get it out but you will most likely have to replace the input shaft seal on the steering box before you put everything back together. i know the pin on mine looks like it might come out but i know someone has replace the steering column and the input shaft on it leaks(pretty sure seal was damaged by heat).
Old Sep 19, 2013 | 09:20 PM
Mopar Trucks's Avatar
Mopar Trucks
I did a Dorman kit on a previous 150 and found that the hole/pin was bigger on one side than the other so not to insult you, have you tried it from both sides?
Old Sep 20, 2013 | 08:36 AM
charlie1935's Avatar
charlie1935
I remember it being tapered too.
Won't go but one way.
Old Sep 20, 2013 | 02:18 PM
wontacceptthis
I did try both sides. I'll see if I can't measure the ID of the pin to see which side is less compressed.
I picked up a pilot punch set today at tractor supply. They are like a non-tapered drift punch with a nipple on the end, specifically for roll pins. We shall see what the appropriate tool and an inappropriately large hammer shall do.
Old Sep 20, 2013 | 05:25 PM
wontacceptthis
10 minutes with the proper punch, and she's out. 1/4" was a little on the small side, but it worked.
One of the perks of working in a machine shop is getting really good advice on rebuilding 70 year old technology.
Old Sep 20, 2013 | 08:39 PM
Mopar Trucks
Hey congrats. Its amazing what the right tool can do.
