Wipers don't reset
Old Feb 4, 2014 | 08:10 AM
mikebrennan's Avatar
mikebrennan
Default Wipers don't reset
Hi again: Not sure If the "Search" link on the forum works that well as I put down variations of "wipers" and came up empty. Anyway, I think I repaired this once on my 79. The wipers do not reset. They just stop anywhere. What is the fix for that.
Thanks
Old Feb 8, 2014 | 02:45 PM
jcruse64's Avatar
jcruse64
More information please. They just stop anywhere at any point, or is it they just stay stopped from the point of motion when you turn them off?
Could be a motor on the fritz, or linkage is binding enough to freeze it up, or your switch in the dash has a problem, or the grounding strap on the wiper motor is not grounded well, or the little ballast resistor mounted on the wiper motor is bad, or the intermittent switch on the firewall is bad.
Old Feb 8, 2014 | 11:37 PM
mikebrennan
Maybe I should get a new truck.
Old Feb 9, 2014 | 08:40 AM
jcruse64's Avatar
jcruse64
Well, that's up to you . Until then, check the things I listed. If it's an issue with the linkage freezing up, that's an easy, inexpensive fix by replacing all the bushings out (done that). A loose ground off the wiper motor; easy fix. Issue with the wiper motor; just replaced one on my '76 RC, and it was less than $60 at the local chain store. No experience with the dash switch, but shouldn't be hard to replace. Try checking the grounds first, and look over the wiring from the switch to the motor.
It's ALWAYS something with about any vehicle. My brother had a blown motor in a Kia last summer that the dealer would not cover. Hang in there!
Old Feb 9, 2014 | 09:07 AM
sls001's Avatar
sls001
Thanks
Again, a factory service manual will give you the exact diagnostic procedure>
From the FSM: Condition - Blades do not park
If motor stops in any position when switch is turned Off - Open Park Wiring circuit or faulty switch or defective motor in that order
Chances are it is the park switch in the motor and there is a diagnostic procedure for that
Old Feb 9, 2014 | 09:23 AM
mikebrennan
Thanks for the replies I can use. I figured it was in the motor and not the bushings. I remember replacing those in my old 79 100. I also remember replacing the motor out of a junker too. However, for now I can park them easy enough with the switch
Old Feb 9, 2014 | 05:22 PM
sls001's Avatar
sls001
I don't have a scanner but here is images from the FSM to diagnose the park switch>
Old Feb 10, 2014 | 07:51 PM
dozer556's Avatar
dozer556
Just goes to show you what the FSM is worth.
Kudos to sls001 for scanning and sharing that info.
Old Feb 11, 2014 | 08:36 AM
mikebrennan
May I double down on that as well.
Mike
