help with fuel system
Old Feb 16, 2014 | 03:35 PM
jcb11realtree's Avatar
jcb11realtree
Default help with fuel system
i jsut found out i have a craked block in my 3.9 tbi motor but i have a mpi 318 i could put in it. could i use the stock 3.9 tbi on my 318 with a differnt intake
Old Feb 17, 2014 | 03:28 AM
crazzywolfie's Avatar
crazzywolfie
most likely won't work right. also to stick a 318 where a v6 was on any 88-93 trucks require a special motor mount extension plate on the drivers side.
Old Feb 17, 2014 | 09:22 AM
jcb11realtree
could i take the v6 driver side motor mount and adjust it so it will fit or will i have to use the v8 mount and adjust it
Old Feb 17, 2014 | 10:36 AM
crazzywolfie
Originally Posted by SixGun
There's been a lot of guys wanting to swap out the 3.9 for a 5.2 motor on a 2WD truck. There has been a lot of speculation on the motor mounts. Well here is the real deal:
The engine brackets from the 3.9 (below) will not fit the 5.2 motor.
You will need the engine brackets for the 5.2 (shown below). Hopefully your donor will have them already on. If not, take note of how the bracket bolts to the "ears" on the side of the motor. It should be on the front side of the "ears". Also, you will need the adapter bracket for the driver's side frame bracket. (shown below) This puts the mount forward and lower.
On the driver's side, the new frame bracket it is held in by 4 bolts instead of 3. The new bracket is mounted as shown below. The old triangle brackets for the frame are no longer needed.
On the passenger frame bracket, the first pic shows how the 3.9 mounts and the second pic is of the new location for the 5.2 motor. Once again, the triangle bracket is not needed. The motor mount is now bolted directly to the crossmember in the furthest forward location. Should be a dimple above the bolt hole.
This pic shows both sides mounted in the new locations. This pushes the mount forward and a little lower. Should be pretty much level and even now.
this shows everything
Old Feb 17, 2014 | 10:41 PM
grantshultz1994's Avatar
grantshultz1994
@ crazzywolfie
in those pics is there a special bracket to buy for that steering shock or is that a custom fab thing? and if its a kit where can I buy one my truck shakes like you wouldn't imagine
Old Feb 18, 2014 | 09:41 AM
jcb11realtree
this is my passenger side motor mount
Old Feb 18, 2014 | 12:21 PM
crazzywolfie
something don't look right about that mount. you might be able to bolt a magnum v8 in there with the mounts but i don't know if i would trust them. even Sixgun had to have his mounts welded because they were separating from the power that the 6 cylinder put out. steering stabilizer is most likely a bolt in kit but you should not likely need one. if you got a shake that is most likely something different.
Old Feb 18, 2014 | 12:40 PM
jcb11realtree
could it be my truck is a w150 with 1 1/4 ton springs
there are holes on the cross member that look like my mounts from the 5.2 will bolt in.
Old Feb 18, 2014 | 01:09 PM
crazzywolfie
the drivers side motor mount is still most likely too far back but you can try and see it it works. i would still be worried that those motor mount pieces that bolt to the block would be too weak which is why they are not used with the v8's
Old Feb 18, 2014 | 01:25 PM
jcb11realtree
i am goin to try to use my v8 motor mounts and mount them to the cross member like they are mounted now
