Oil pressure warning light! Engine swap questions
Old Mar 10, 2015 | 05:08 PM
goldsmobile's Avatar
goldsmobile
Default Oil pressure warning light! Engine swap questions
1991 d150 with the 318. This happens when i get off the highway. The oil pressure warning light comes on and now the gauge is dipping lower than I've ever seen it. I checked the level and it was fine. This truck did a lot of sitting before i got it and I'm concerned that the oil pickup is partially clogged or the main bearings have a lot of wear causing excessive clearance. It has a piston slap sound when its cold in the morning. Im not sure what to do.
Im of the mindset since this is my daily that i might want to find a good motor to swap in. I have to pull this one because of multiple bad oil leaks so if I'm pulling it then i might as well upgrade.
So with that said....im thinking of either a 318/360 magnum motor from 92/93 or a cummins. How much am i going to be dealing with to do these swaps? Im no stranger to motor swaps but have never done a dodge one. I know with the cummins i would need to swap in another tranny as well. thats fine as i want overdrive.
Old Mar 13, 2015 | 06:19 AM
goldsmobile
152 views and no responses?
I think I'm leaning towards doing the magnum swap for budget reasons. Has anyone done TBI to Multiport on this board? Things i should know going into it? I would also be going to the 4 speed overdrive at the same time. Do i need a new steering column with auto shifter to do this? I currently have the three speed auto.
Old Mar 17, 2015 | 11:07 PM
Scooter78's Avatar
Scooter78
https://dodgeforum.com/forum/2nd-gen...a-1st-gen.html
Been running mine for over a year now. Works great
Old Mar 18, 2015 | 06:17 PM
goldsmobile
Nice. Yea I'm taking the plunge. I lucked into finding a 93 with a magnum 360 and an overdrive trans recently rebuilt but i guess everything about the truck is real rough except the motor and trans. Im going to pick the whole thing up and swap what i want over to it my rig. Should make for a fast-ish fun work truck being that mine is a D150 shortbed.
