1980 dodge w150
Old May 5, 2015 | 10:03 PM
tadmorris95's Avatar
tadmorris95
Default 1980 dodge w150
I got a 1980 dodge w150 with the 5.9l just found out its not firing on cylinder 7. Its getting spark. And i just put on a new edelbrock 600cfm carb with a edelbrock preformer rpm airbag intake manifold. What could be causing it not to fire?
Old May 5, 2015 | 10:58 PM
Getting spark but not firing?
Old May 6, 2015 | 09:15 AM
tadmorris95
Yeah im getting a spark from the plug but i can unplug the wire from the sparkplug and there is no difference. So would it be no fuel getting to that cylinder?
Old May 6, 2015 | 09:24 AM
Thats exactly what it sounds like, or no compression.
Old May 6, 2015 | 09:31 AM
tadmorris95
Alright ill check compression and fuel when i get home from work. Thanks for the advice ill let ya know what i find out
Old May 6, 2015 | 01:23 PM
tadmorris95
Do you know what the compression should be for that motor?
Old May 7, 2015 | 11:55 AM
KevenP's Avatar
KevenP
Depending on the mileage, between 125 and 175.
All cylinders should be within 10% of one another.
Old May 13, 2015 | 05:27 PM
tadmorris95
Im running about 75 psi on all 8, is that typical for a 1980?
Old May 15, 2015 | 10:32 AM
Moparite's Avatar
Moparite
75 is a bit low. How many miles on it?
Old Jun 4, 2015 | 12:19 PM
emnestor's Avatar
emnestor
:i con_lurk5:
