Both Headlights Not Working
The headlights on my 1991 Ram 250 are not working. It is the low-beams only. I have been checking forums for the past two days but haven't been successful. Here is what I think I know:
High-Beams won't stay on. They come on when I pull the switch but, once I let go, they turn off.
The running lights and everything else work.
Fuse is good - unless there are fuses under the hood that I am unaware of. The engine bay is pretty sparse so I don't think I am missing anything.
There doesn't seem to be a relay for the headlights. My guess is that it's built into the dimmer switch.
I changed the dimmer switch (seemed to be most common on the threads) and they still didn't work.
I just found out today that the wipers don't work either. If anyone has any recommendations, please help.
Anyone have any more ideas? Is there a fuse box under the hood that I am not seeing? Is there a relay for the headlights I am missing? I updated my post to say that the wipers don't work either.
"Moparite" said the switch doesn't have anything to do with the headlights. Should I go ahead and try it anyways?
Does anyone have recommendations on troubleshooting?
Any help would be greatly appreciated.
Sorry, I was talking about the multifunction switch. The brights come on when I pull it but turn off once I let go. The multi-function switch is the one I replaced too. It didn't have any effect.
