1990 Big Block swap.................
Old 10-09-2015, 12:09 PM
KevenP's Avatar
KevenP
KevenP is offline
Just a few more things I've learned. Hopefully this will help someone in the future.
Big block alternator and power steering pump brackets will work.
Buy long tube headers, not block huggers.
These motor mounts will NOT work on a '90:
Trans Dapt 4565 engine swap motor mount kit.
These are the motor mounts you need:
72 & Up 4WD Truck B/RB Swap or Replacement Kit
http://engine-swaps.com/Pages/Produc...7BRBtruck.html
You will need to convert your ignition to the old style system.
Find a passenger side dump water pump housing and the original lower radiator hose will fit.
Old 10-10-2015, 11:31 AM
Moparite's Avatar
Moparite
Moparite is offline
As long as you have a pic up coil you can use the electronic mopar ignition or use a MSD box.
Old 10-11-2015, 01:01 PM
KevenP's Avatar
KevenP
KevenP is offline
By 'old style' I meant the Mopar electron ignition, not points.
Old 10-11-2015, 01:54 PM
Moparite's Avatar
Moparite
Moparite is offline
That's what i meant.
Old 10-11-2015, 03:47 PM
KevenP's Avatar
KevenP
KevenP is offline
I guess if you cut the factory wire harness apart and knew which 2 of the 3 wires to use, you wouldn't have to change it completely.
Old 10-11-2015, 08:13 PM
Moparite's Avatar
Moparite
Moparite is offline
All you need is the pick up coil in the distributor(two wires). You can hook up a msd box or the mopar electronic ignition to it. The msd is the easiest to do.
Old 10-11-2015, 08:59 PM
KevenP's Avatar
KevenP
KevenP is offline
Good info.
Do you have the information on how to tie into the factory ignition?
Old 10-12-2015, 09:39 AM
Moparite's Avatar
Moparite
Moparite is offline
Factory ignition? What do you call factory ignition? The mopar electronic ignition? The one on your truck was controlled by pcm.
Old 10-12-2015, 01:45 PM
KevenP's Avatar
KevenP
KevenP is offline
Yes, the factory ignition controlled by the PCM. Mine has a 3 wire plug at the distributor. Is there a way to use a 2 wire distributor with this system?
Old 10-12-2015, 06:05 PM
Moparite's Avatar
Moparite
Moparite is offline
The 3 wire set up was for the pcm vehicles. One power one ground and the other was the signal wire. What dizzy do you have for the 383?
Quick Reply: 1990 Big Block swap.................
