Need help finding a wiring harness
The ignition switch went out on the truck in my sig a few days ago. I wasn't in a huge hurry to get it fixed at the time. Then it turned out that I was going to need it this week. I was having a hard time trying to find the switch in time so I decided I would go with a toggle switch and push button for the starter since I had everything I needed laying around. Just until I could get a new switch in.
I got it all wired up no problem, turned out that the battery was also dead. Bought a new battery and when I put it in a bunch of the harness fried. I pulled the cables right away and once the smoke cleared i got to see the damage.
The way it looks right now the easiest thing to do is get a new harness and rewire the whole truck. The problem is that I can't seem to find one anywhere.
Does anyone know where I could find one. I haven't had any luck with junk yards. I've even looked into the painless setups but it looks like they only have one for Mopars and it only goes up to 76 i believe.
I have been thinking about doing this since I got the truck. I don't have much of a choice right now. I think I am about the 5th owner and the wiring was real bad before i started on it. At one time it was a fire truck in Texas, and went all over the country after that. There are wire nuts and loose wires everywhere under both the hood and dash.
I would likely be in BOOK form on that one. Those had fusible links too.
http://repairinfo.alldatadiy.com/Dod...atic_H2t78.php
