Where to buy cab mount brackets?
To pass inspection, my '87 W250 needs cab mounts. I will buy the Energy Suspension poly kit to replace the rubber mount bushings.
However, I want to know where to buy the metal brackets that rivet to the frame rails.
Also, not that I can't figure it out as I go, but does a DIY exist for this job? I searched but didn't find anything.
Thanks.
Thanks.
Thanks.
Also have a second question, now that I'm doing more research. Inspection shop says the truck needs new ball joints. Looking around the internet, I gather the truck has a Dana 60 front setup, but everything I read says the truck should have the kingpin version, not the ball joint version.
Well I looked under the truck and sure enough, it has ball joints. What gives? Was this axle swapped in at some point? How do I know which ball joints to order?
