360 magnum won't start
Old Aug 26, 2017 | 07:11 PM
oldschool62's Avatar
oldschool62
Default 360 magnum won't start
I have a 93 360 magnum I bought at salvage trying to start out of truck .It will crank won't start jumping across starter what do I need to do to get fire to coil .I have the ECM hooked up .any help will help
Old Aug 26, 2017 | 10:09 PM
Is the crank sensor in place? Sits behind the passenger side head. Got a flexplate, or flywheel on there for the sensor to read?
Old Aug 26, 2017 | 10:59 PM
oldschool62
Yea sensor is hooked up I don't know how to get power to ECM I have complete engine harness hooked up to ECM it has three pig tails that hook to another harness I thine one of those should have my hot wire to feed ECm
Old Aug 27, 2017 | 09:35 AM
Moparite's Avatar
Moparite
Pcm gets power from the battery and the ignition switch. Do you have the relays/fuses hooked up? You need the ASD relay to supply power! I would suggest to get a wiring diagram. The new motors are not like the old school ones where all you need was power to the ignition and starter.
