84 Dodge Ram D100 Custom, stalling whenever
Old Oct 29, 2017 | 02:00 PM
Jim Robbins's Avatar
Jim Robbins
Default 84 Dodge Ram D100 Custom, stalling whenever
Hello All, I have a 1984 Dodge Ram D100 Custom, Slant 6 (225) 3.7 L , and it is stalling whenever it wants at low speeds (stopping, turning corners, going into reverse, any time when my foot is off the gas). Truck has been running and working fine for a long time, no problems. Changed plugs & wires, PCV, in the last year.
I have changed the fuel filter, then decided I need advice from you, what would you check out or replace. Do I have to get the Ram into a Auto Mechanic, without knowing the possible problems (?)
Thank-you for your time. Jim
Old Oct 29, 2017 | 08:21 PM
Might be float isn't letting enough gas into the bowl. Choke might be sticking. May just need to adjust base idle......
