1990 w150 auto trans shifts into reverse Hard
HeyYou, I have found that my truck does not appear to have a TV cable, but rather a kick down rod from carb to trans. The rod has a little movement at carb which translates to a lot of movement on the transmission end. I have removed the rod and pivots to look for wear on the pivots but have noticed that the slotted long bracket that runs from the rod to the carb has the slotted end at the rod pivot facing the firewall...all pictures I can find show other versions of this setup with cables or rods with the slotted bracket at the carb shaft end???
Which is correct for my model? 1990 W150, 318 auto with kick down rod.
thanks for any insight, pictures. If this rod is supposed to move with the throttle movement but has slop which delays it could be the cause of the trans issues.
