91 Ram W150
Old Dec 17, 2017 | 11:17 AM
Branden Campbell's Avatar
Branden Campbell
Default 91 Ram W150
I am trying to do the front wheel hub, rotor, and bearings. I have the caliper and wheel hub cap off and now just stuck how to get the rest undone.
Old Dec 17, 2017 | 11:25 AM
Looks like that round thing with the notches in it in the middle is holding it on. Need some kind of special spanner wrench to screw it off.
Old Dec 17, 2017 | 11:31 AM
You can get the socket for those 'nuts'....... there is two of them in there, the outer one, then a keyed spacer, and an inner. Take those three pieces off, and the whole rotor/hub slides right off.
Old Dec 17, 2017 | 01:39 PM
crazzywolfie's Avatar
crazzywolfie
this should be what you need. i wouldn't try taking those nuts off without the special socket. sometimes you can find the socket at local parts stores but they are starting to be a bit more uncommon
https://www.summitracing.com/int/parts/wmr-w1269
Old Dec 17, 2017 | 07:07 PM
Branden Campbell
Thank you for the help I got it off with that socket found it at NAPA
Old Dec 18, 2017 | 09:43 PM
silvermopar's Avatar
silvermopar
Be sure to tighten it right when you go back together!
Old Dec 21, 2017 | 10:58 AM
fj5gtx's Avatar
fj5gtx
You probably want to put a new tie rod in there, that boot is shot and it doesn't look like it has any grease ooozing out... Its screaming replace me...
Regards,
The tie rod whisperer....
Old Dec 23, 2017 | 11:44 AM
Moparite's Avatar
Moparite
I'm sure you will find other things like this that need to be replaced also! What do the axle u joints look like? Now is the time to replace them while you are at it.
