Coil wiring on 92 d250 with 360
Old Jan 2, 2018 | 07:54 PM
92d250's Avatar
92d250
Default Coil wiring on 92 d250 with 360
Just bought back a 92 d250 with a 360.truck quit running on p.o. and they took off the coil.which color wire is the positive and which is the negative?
Old Jan 2, 2018 | 09:44 PM
Pink wire, if you have one, should be positive. Black/yellow is negative.
Old Jan 3, 2018 | 03:58 AM
crazzywolfie's Avatar
crazzywolfie
the grey wire should go to the negative side and the dark green/orange wire should go to the positive. you can even double check it with a test light or multi meter. the coil positive wire should have power for a few seconds after you cycle the key on so a test light should light up if you hooked it up positive coil wire.
