88 w100 power ram
Old Feb 3, 2018 | 05:17 PM
James Hager's Avatar
James Hager
Default 88 w100 power ram
Hey guys I'm new to the forum. I'm trying to figure out why my 4wd will not engage. I have manual hubs and neither 4 hi or 4 low will work. Transfer case feels as though its working, 4 low is as it should feel but front wheels will not pull. Please help!!!
Old Feb 3, 2018 | 07:44 PM
IS the front shaft turning? If you jack up the front, lock in the hubs, and spin one tire, does the driveshaft, or opposite tire turn?
Old Feb 3, 2018 | 08:55 PM
crazzywolfie's Avatar
crazzywolfie
best place to start is jacking the front axle up so both tires are off the ground and locking the hubs, should be able to spin the 1 tire and have the other tire spin too. it is possible that the hubs are not locking.
Old Feb 3, 2018 | 11:35 PM
Black Rhino 1's Avatar
Black Rhino 1
Actuator motor not engaging the axle?
Old Feb 23, 2018 | 09:47 AM
James Hager
The Hubs are locked and wheels still spin free. Drive shaft will not spin. Any thoughts?
Old Feb 23, 2018 | 09:49 AM
James Hager
the hubs click as though they are locking.
Old Feb 23, 2018 | 09:54 AM
James Hager
hubs are locked and wheels still spin free. Hubs click As though they are locked. Shaft does not turn by hand. Any thoughts?
Old Feb 23, 2018 | 12:11 PM
You need to pull the hubs, and see what things look like.
Old Feb 23, 2018 | 12:37 PM
crazzywolfie
does it have a cad unit on the axle? if 1 wheel spins while the other doesn't the cad could be causing issues or there is a possible issue with the hubs if everything else it working but the hubs are clicking like you have said
Old Feb 23, 2018 | 03:56 PM
James Hager
Yep, its the cad. Thanks a million!!
