1989 Dodge Ram D100
Old Jul 24, 2018 | 05:41 AM
Sebastrulas's Avatar
Sebastrulas
Default 1989 Dodge Ram D100
I just got a 1989 Dodge Ram D100 with a 319 2wd. What kind of differential fluid do I use and engine/ trans oil do I use to. It’s going to be my daily. Also thinking of welding the diff.
Old Jul 24, 2018 | 07:21 AM
http://dodge-trucks.oilsr.us/d100_2w...p/1989-5.2L-Y/
Old Jul 24, 2018 | 08:05 AM
Going to be driving it on the road? Then don't weld the diff.
Old Jul 25, 2018 | 09:35 PM
crazzywolfie's Avatar
crazzywolfie
if you don't know what transmission you have it is best to use atf+4. if you know the truck does not have overdrive you can use the dexron/mercron stuff which is a bit cheaper. shell 15w40 is all i usually put in my engines. it seems to keep them running strong and healthy even when i don't treat them the best.
