EFI flooding
Old Jul 29, 2018 | 01:39 PM
billyreg40's Avatar
billyreg40
Default EFI flooding
I have a 89 dodge D-150 with throttle body injection. Recently it has started to act as though it were a flooding carburetor. If you look into the injector with it running you can see fuel on the air plates . Is really bad at idle but runs good at higher rpm. I have tried MAP and fuel pressure regulator. I also replaced the ECM, but same results. Any suggestions as to the cause?
Old Jul 29, 2018 | 07:07 PM
Possibly coolant temp sensor. Check it. You may have two. You want the two wire feller.
Old Jul 29, 2018 | 10:50 PM
crazzywolfie's Avatar
crazzywolfie
i would be checking the hall effect sensor. if that isn't it i would almost wonder if it is a sticking injector.
Old Jul 30, 2018 | 09:45 AM
Moparite's Avatar
Moparite
Look down it and rev/run it at rpm and see what it looks like. If one is just dumping fuel and the other is spraying it then you know it's an injector. When was the last time you did a tune up(cap rotor plugs)? Any codes?
