93 d150 cranks wont fire
Old Nov 24, 2018 | 08:48 AM
Originally Posted by Moparite
It uses both, The engine on initial start needs to see the crank signal(so it knows it's turning) then it looks for the cam sensor(so it knows where the engine is (cylinder #)) before it fires the coil. The crank needs to make one complete rotation before this happens. I also think the pcm is not seeing the crank signal so further investigating is in order.
It uses the crank sensor to determine if the engine is turning, and I think the cam sensor just needs to change state once, for the computer to know which injector to fire......
Old Nov 24, 2018 | 05:08 PM
cheeks7578's Avatar
cheeks7578
Found a broken wire connection at the junction of the black/blue stripe wire by the bell housing. Fixed the break and it fired up! Runs rough from the seafoam I put in the tank but it runs! Now to put it back together.
