O2 sensor help
Old Jan 31, 2019 | 09:04 PM
cdgreen702's Avatar
cdgreen702
Default O2 sensor help
Son and i built 90 d150 from several wrecks Turned out beutiful but having running issues that were beyond our capabilities. Took it to a mechanic who determined the computer was bad. Replaced it and things got better with several of the systems. Problem is after it warms up it runs like crap. He believes it is because it has no o2 sensors. Easy enough to put on new exhaust but have no idea where they plug into harness. Help
Old Feb 1, 2019 | 10:07 AM
crazzywolfie's Avatar
crazzywolfie
there should be a connector on passenger side of the engine near the back that pugs into a extension that runs over to the drivers side somewhere. you definitely need a o2 sensor in order for the engine to run right. also make sure to get a NTK brand sensor
Old Feb 6, 2019 | 11:23 AM
cdgreen702's Avatar
cdgreen702
Default Thanks
I located another wreck that was still fairly intact and it had the sensor still on it. I was able to pull off the harness I needed so hopefully this takes care of it. Thanks for the help.
