1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I'm currently resurrecting a 88 w150 that I just bought. It was sitting(rotting) for about 8 years. Changed T.Case fluid today. When I drained it only a quart came out. Many online sources say it holds 6 pints or 3 quarts. When I refilled the case I could only get 2 quarts in it. Could not get another drop in without it running out and I was on level ground. Any ideas?
I did that with brake cleaner after I drained it. With straw on can I sprayed half a can in there. It all ran out. Nothing obvious came out. I will run the 4x4 through all the gears for 5 minutes or so and drain it again.
