87 leaf spring hanger
Old Apr 1, 2019 | 12:12 PM
Kyleh2486's Avatar
Kyleh2486
Default 87 leaf spring hanger
Does anyone know where I can find new replacement front mount of the rear leaf spring hangers/perches for an 87 D100?
Old Apr 1, 2019 | 05:58 PM
crazzywolfie's Avatar
crazzywolfie
you can try contacting Jungle Jim on ramcharger central. i don't know if he has brackets that work with stock spring bushings but pretty sure he does build a kit for stock height if that is what you want. his bracket's are top quality. installed them front and rear on my buddies truck and they look awesome. even had a vehicle safety inspector compliment him on the quality of the brackets.
Old Apr 7, 2019 | 03:05 PM
u2slow's Avatar
u2slow
My best googling shows the fwd ones are discontinued, but the rear is available.
You might try 2ndgen ones from a 1500 (for 2.5" wide leafs). Should work because the frame width and axle perch spacing stayed the same 1stgen vs 2ndgen. Probably have to drill some holes is all.
