Spool/locker 9.25
#21
I've driven a lot of trucks with Lockrights and Detroits. Always manual trans. They lock and unlock with the throttle.
I finally tried one with an automatic. Did not care for that. Might as well have installed a spool. The auto never lets up on input torque, so it doesn't release. Swapped that whole diff into a cummins truck (5spd) where it works 'properly'.
IMO, go with a Ford 9", and run a $30 mini-spool.
#22
An auto locker will unlock any time the outside tire tries to spin faster than the carrier. Doesn't matter if you are on the throttle or not, I have them in manual and auto transmission vehicles they work great in both. The auto makes it less noticeable.
#23
Sounds good in theory. I could not effectively jockey my trailers around tight quarters with an auto and lockright. BTDT.
#24
#25
Auto and stick don't work the device the same. Input torque with the auto is continuous.
#26
If it acted like a spool the whole time you had the auto in gear then it wasn't working correctly, that isn't how an auto locker should work.
#27
Buddy put a Detroit in his chevy 14bolt. Auto truck... same beef about being a spool 99% of the time.
#28
#29
#30
An auto locker is always locked reagadless of torque, the springs keep it engaged, the cross pin is what transfers the torque to the side gears. In a turn the slack in the locker will allow the outside axle shaft to uncouple and turn faster than the carrier while the inside tire is the one being driven by the engine torque.
