Adding AC
Old Jul 20, 2019 | 11:04 PM
MUTTONCHOPS81's Avatar
MUTTONCHOPS81
Default Adding AC
I have a 1990 Dodge D250 5.9 gasser and I do not have AC. I would like to add it to the vehicle and have been looking at the under dash units. To make this as easy as possible trying to find a AC compressor mounting bracket and hardware. Anyone no where I can find one or have one laying around?
Thanks
Old Jul 21, 2019 | 08:08 AM
Junk yard. May be more effective to find a truck that did come with a/c, and take all the parts you need from it.
Old Jul 21, 2019 | 11:34 AM
primem's Avatar
primem
if you have to buy new...you'll be into it for $1500 just for parts
you'll need
belts
bracket
condenser
evaporator
accumulator
fixed orfice
high and low side lines
hvac controls
compressor
wiring
refrigerant
pressure switch
Old Jul 21, 2019 | 09:01 PM
crazzywolfie's Avatar
crazzywolfie
why would you need brackets? i believe all 88-91 just have a idler pulley in place of the a/c compressor. no cheap or easy way to install a/c on a non a/c truck. you have to get a a/c heater box and all the parts to make it work which are getting harder to find. might almost be better off to look at a aftermarket a/c system like you sometimes see in classic cars.
