What to take on a road trip with a 1984 B250
Old Jul 26, 2019 | 02:17 PM
redyellowgreenblue@gmail.com's Avatar
Default What to take on a road trip with a 1984 B250
Hi,
I've bought a 1984 B250, and plan to take it for a road trip across Canada - total distance will be around 15000 miles. I've had the van serviced, oil and filters replaced. Is there any sort of consumible I should be taking with me on the trip apart from more oil?
Old Jul 26, 2019 | 02:24 PM
ol' grouch's Avatar
ol' grouch
Originally Posted by redyellowgreenblue@gmail.com
Hi,
I always take with me on long trips, jumper cables, first aid kit, crunchy snacks to stay awake, a case of bottled water, cooler of soft drinks, at least one roll of comfortable toilet paper (the stuff in truck stops I've used with some WD-40 to take rust off hydraulic cylinders) a tool box, a couple of jugs of coolant (antifreeze or water) a fuel can, full or empty, just have one with you, sleeping bag, bug repellent, replacement belts and hoses and at least one credit card. Plus plenty of cash.
15K seems a bit extreme for a 35 year old vehicle. I could do it with my stuff but I've gone through all of it.
Old Jul 26, 2019 | 06:02 PM
crazzywolfie's Avatar
crazzywolfie
a spare ignition module and ballast resister. a jug of distilled water wouldn't hurt with how cheap it is. basic tools wouldn't hurt to have but probably shouldn't be needed if it was taken care of. i would have no issue taking a 15,000mile trip in a old vehicle. only thing that sucks is the fuel bill. i am guessing about $6k in fuel. if you had over overdrive i could see the road trip costing about $2000 less on fuel. i know Ontario to Alberta and back in a new charger cost about $600 in fuel averaging about 33-39mpg.
Old Jul 26, 2019 | 06:14 PM
ol' grouch's Avatar
ol' grouch
Doh! How could I forget the porcelain savior! It's been so long since I had a non-computerized Mopar I forgot about the ballast resistor. I used to carry one in my tool box wrapped in a towel. The brain box, not so much as they will mostly interchange and used to be readily available.
Old Jul 26, 2019 | 07:23 PM
Porcelain savior? Here I was thinking "toilet"......
Carry the various fluids your van likes, spare belts, and the tools to change 'em.
Old Jul 26, 2019 | 07:30 PM
ol' grouch's Avatar
ol' grouch
The resistor blows at inopportune moments. As for toilets, we're, well at least I'm a guy. A bush or tree will work for me.
Last edited by ol' grouch; Jul 26, 2019 at 07:33 PM. Reason: I kant spel wurth a durn
Old Jul 26, 2019 | 07:31 PM
Just be careful what leaves you try and use.
Old Jul 26, 2019 | 07:38 PM
ol' grouch's Avatar
ol' grouch
Depends. Goodness, this thread sure went south fast.
Old Jul 26, 2019 | 07:49 PM
That never happens here.......
