Speedometer not working
Old Aug 1, 2019 | 11:07 PM
david.baker294's Avatar
david.baker294
Default Speedometer not working
I have replaced the speed sensor in my 91 d250 gas burner and my speedometer still isnt working, neither is the overdrive. Please help
Old Aug 2, 2019 | 09:04 AM
Which sensor did you replace? (where was it?)
Old Aug 2, 2019 | 09:06 AM
david.baker294
Speed sensor on the tranny
Old Aug 2, 2019 | 09:08 AM
Well, that's the right one..... are you getting any codes for it?
May wanna verify it's getting its 5 volt feed from the PCM.
Old Aug 2, 2019 | 11:11 AM
crazzywolfie's Avatar
crazzywolfie
i don't think these have a 5v signal. just 2 wires. 1 is ground and the other goes to speedometer, pcm and DRL. if the speedo is not working and you have no overdrive i would assume you may have a bad ground or possibly a damaged wire somewhere between the sensor and the speedo and pcm. you can test things with a multi meter.
Old Aug 14, 2019 | 04:06 PM
david.baker294
I do have 5v to the sensor. Yes it is only 2 wires
Old Aug 14, 2019 | 05:06 PM
crazzywolfie
if the one has 5v to it then make sure the other one has a good ground. if thing still don't work there is a good chance something may be broken in the speedo head.
