Help me diagnose loose bearings...
I have a loose bearing, let me describe it:
- it sounds like marbles hitting each other (not crankshaft/engine whir)
- sounds like under front of truck (not wheel bearings, just replaced them)
- when I accelerate, it makes noise - the faster/harder accelerate, the more noise. when I cruise with foot off pedal, it doesn't. when I'm in neutral and moving, it doesn't.
Spark knock?
Bad or spun bearings... If the bearing/s are worn you will hear the engine make noise until you build oil pressure(as soon as you start it). A spun bearing you will hear after it heats up usually slightly higher than idle(depending on what condition it's in). You can you give more info like when do you first here it. A sound clip(video, post it on you tube and link it here).
1989, had EFI stock but that was all changed awhile ago to carb and deletion of all emissions systems.
How would I adjust the distributor... just moving it one way or the other? I recently took it off and cleaned it for another issue and put it back where it was before. But I'm not sure if this sound was there before or not since I bought the truck a couple months ago.
Trending Topics
i could tell approximate age from the key. that is the newer style key. never seen a 89 with it but knew it might be possible.
just have to rotate the distributor. i believe you need to rotated it whichever way makes the engine idle lower. if you had the distributor out you may have messed this adjustment up.
I'm wondering if it's preignition after reading http://www.misterfixit.com/deton.htm
Sometimes when I shut off the truck the cylinders still fire for a few seconds. But the thermostat never shows the engine as running hot - which I know could be defective possibly. I know there is enough coolant in there as well.
timing being too far advance can cause sounds like you are having and for the engine deiseling on when you shut the key off because the cylinder is getting too hot. stock temp gauge is junk along with the amp gauge. oil pressure one is ok along with gas gauge when everything is working.
