Lean burn system delete
Old Oct 13, 2019 | 08:40 AM
Moparite's Avatar
Moparite
I would love to do an intake and carb but that's nearly $1000
I have never paid any where near that for any intake/carb combo. The most expensive piece i bought was a mopar 6 pack intake with carbs for something like 300$. Of course this was back in the day before the internet and it was used. Look on ebay-craigs list for intakes/carbs. I buy used stuff, and with some cleaning up and carb rebuild it will work like new. I like holley carbs because they are easy to work on and you can get anything you for them. Intakes the worst thing you will come across is the bolt holes for the carb are stripped or broken off. A weld and a heli coil and it's fixed. If you have a bone yard near you you can get everything you need for the ignition as long as they have vehicles from that era witch today seems to be a problem. I'm sure you can get it off of ebay with some looking. If you have swap meet near you they are a great source for parts but the season is over until spring. And for the vac advance on the distributor you need throttle vac not manifold vac. Using manifold vac will give you full advance at idle and drop off (retard the ignition) during acceleration(opposite of what you need).
Old Jun 21, 2021 | 08:23 AM
Ghock100's Avatar
Ghock100
By chance did you ever get this problem solved. I have a 87 D150 doing the exact problems. Only thing i haven't replaced is the distributor and the lean burn box.
Old Jun 21, 2021 | 11:46 AM
ol' grouch's Avatar
ol' grouch
Rather than continue an old thread, where you will get lost in the shuffle, post a new thread. Detail all the items regarding it. The year, engine, what you've done, what the problem is and so on. Especially the miles on the engine. Then we can all pile up on you. Seriously, there are enough retired and currently working mechanics and tinkerers that we ought to figure it out.
Old Nov 2, 2021 | 01:58 AM
Matthew w's Avatar
Matthew w
Default If it has the 2 b carb.
I am restoring a 86 w150 short wide 4 speed granny. And when this truck was doing that I replaced a part on the carb on the right side here is a pic of it . And the cost it stopped all the issues even the dumping gas into the oil. I am putting on a hei distributor 4 b carb and manifold . But this was to get it going while I purchase parts as they are hard to come by and not all of them cheap. Best of luck to you
Old Nov 9, 2021 | 06:10 PM
volaredon's Avatar
volaredon
It may be a lean burn, the unit looks like one but I've never seen one like that. My old '88 Diplomat had it on the air cleaner. Just to make sure, before you buy a new ignition system, replace your ballast resistor and hook a vacuum gauge to the intake. I'm looking at those headers and wondering how well the exhaust is flowing.
That IS a Lean burn. They moved them off the air cleaner to cut down on heat and vibration, a common reason they went bad.
I had 2 Diplomats over the years. 1 was police interceptor version. That one had the LB behind the battery in the fender as well.
OP is on the right track to $#!tcan that lousy ignition system. You will need a different distributor AND carburetor. You need a carb with a vacuum nipple for vacuum advance, and of course a distributor with vacuum and centrifugal advance
Old Nov 29, 2024 | 12:21 PM
Rowh's Avatar
Rowh
Originally Posted by msmith5150
Hello all! I know there is a lot of info out there about this subject. Believe me, I have been scouring through that info until my eyes hurt. I recently purchased a 1987 D150 LE with a 318 for my son for his first vehicle. I knew there would be repairs needed and I have done quite a bit to it. It has been running well until a week ago. It died on him on a busy highway and i had to rescue him.
Anyway, I have, prior to this, already replaced the plugs and wires, cap and rotor. I can't seem to find a vacuum leak. The air pump is not there. I tried a reman spark control unit (the one behind the battery) no luck. The same story, engine fires right up but idles like garbage and dies. Have to throw it into neutral and feather the throttle to keep her running. So I think I need to ditch the lean burn. From my research, some places say just get a kit like this https://www.jegs.com/i/JEGS/555/40500K/10002/-1 and some other info says I also need to replace the carb.
I can't find a definitive "this is what you need to do" to handle this issue. I'm hoping the gurus here can help be get down to brass taxes here. Thanks for any help.
Hey, don't know if this the right place. I wanted to ask a question about a 1987 Dodge D150 LE.
Jeff Rowh
Old Nov 29, 2024 | 12:23 PM
Rowh's Avatar
Rowh
Hey is this the right place to ask for some advice on a 1987 Dodge D150 LE?
Old Nov 29, 2024 | 12:29 PM
You are in the right place, just start a new thread, tell us what you drive, and what your problem is.
