Transmission issues
Old Feb 21, 2020 | 06:50 AM
bc316's Avatar
bc316
Default Transmission issues
I have a 88 d100 with the 318 auto transmission. The issue I'm having is the transmission only works in reverse, no foward gears are working. When its put into drive it dies. Is the transmission total crap? Is it more economical to fix the one i have or just replace it? Thanks for any advice or input.
Old Feb 21, 2020 | 11:40 AM
crazzywolfie's Avatar
crazzywolfie
have you checked the fluid level with the truck in neutral?
Old Feb 21, 2020 | 05:16 PM
bc316's Avatar
bc316
Not yet. I bought the truck from a mechanic who said he was just gonna swap the transmission. But im gonna do my own inspection tomorrow.
Old Feb 22, 2020 | 04:20 PM
bc316's Avatar
bc316
The fluid was low, topped it off didn't seem to help. It has a rough idle and will kill the engine anytime i pull it into gear.
Old Feb 22, 2020 | 04:56 PM
Any codes?
Old Feb 22, 2020 | 05:30 PM
crazzywolfie
did you check it with the transmission in neutral while the engine is running? the transmission doesn't pump in park. have you done a tuneup on it?
