Ideal Kickdown Setting
Old May 11, 2020 | 01:47 PM
  #21
jacob's Avatar
jacob
Im thinking I may need to rebuild this thermoquad. It started up with the turn of a key, let it idle a few minutes. I messed with the idle mixture until I was able to get vacuum up to around 17 with choke held off and at low idle. After a few minutes I shut it down and checked opened up the secondaries. Looking down into the bore, I can see liquid has running down into the intake. This probably explains my difficulty with hot starts.
Based on my research, I suspect either the bowl is cracked, or the orings under the jets are shot. Fun times.
Old May 11, 2020 | 02:56 PM
  #22
crazzywolfie's Avatar
crazzywolfie
if the carb has done any sitting with old fuel it will most likely need it. i know if it was a holley it would likely be a float issue on the secondaries but not sure on a thermoquad. you may just have to pop the top off it to see if there is any obvious issue with it. too bad you didn't live closer. i even have a quadrajet sitting downstairs on a old 360 intake that you could try out for me lol. i bet it leaks but it might run a engine decent,
Old May 11, 2020 | 03:00 PM
  #23
jacob's Avatar
jacob
Apparently the QJ has orings under the jets, which I didnt realize. I took it all apart and cleaned everything out, but never thought to look under the jets. Apparently pretty common for them to get missed. I ordered up a rebuild kit, so hopefully I can get her tuned up. In the meantime though, I have plenty of body work to keep me going, and it still drives well enough to move it around the yard. So thats a bonus.
Thanks for the offers though... if this doesnt work then maybe I will hunt you down... I would be happy to try out your fitech for you too if you want ahaha
Old May 11, 2020 | 03:12 PM
  #24
crazzywolfie
sounds good
lol i bet you would lol. it was actually working pretty good up until the cam wiped a lobe or lifted failed. i really can't wait till the warm weather gets here to swing it onto the elcamino. i bet you probably got the couple inches of that white crap where you live also this morning. was not expecting it here. so much for spring
