1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
This sensor near the Tstat housing drivers side near front of engine on my new to me 1983 W250 with 318 engine - no lines connected (?) what is this - looks like it is a coolant fed circuit but to where? Carb?
[QUOTE=HeyYou;3495003]Thermal vacuum switch. Likely was for the warm air actuator on the air cleaner.[/QUhttps://www.facebook.com/marketplace/item/258476975425365
hmmm . . looks like it could be potentially an emissions thing - will check engine vac diagram, thanks!
Reason: error
Label on my inner driverside front wheel identifies it as "CCEV" and shows vac to front of carb (I see where that has been capped off) and the other vac line to the vacuum advance which is probably pulling manifold vac somewhere. Ah the mysteries of a new vehicle . . .
