Steering package
Old Jan 13, 2021 | 06:01 PM
BM9NBA2's Avatar
BM9NBA2
Default Steering package
Hey guys is there any company that offers a full front end/steering package for the 1st gen Cummins? Like an all in one instead of buying everything separately/individually. Figured would probably save a good amount of money that way.
Old Jan 13, 2021 | 07:31 PM
Polye86_RoyalSE's Avatar
Polye86_RoyalSE
Not sure if there’s any place that sells stock stuff as a package. But I’m sure there are aftermarket kits.
Rock auto should be a good go to, everything I’ve ever ordered there has shipped quick and came at once 🤷🏻‍♂️.
My front end rebuild list is about $600-$650 with stock spec parts. My look into it?
Old Jan 13, 2021 | 07:40 PM
crazzywolfie's Avatar
crazzywolfie
i don't think there is any kits because it really depends on how far someone wants to take things? you can spend $1000's rebuilding the front end depending on how far you want to go and what brand parts you want. what makes you think you need a complete front end or steering rebuild? also have you checked your steering coupler? most of the time that is where most of the slop is found on these if you have slop in the steering. you can now get a knock off borgeson for pretty cheap that does the same job. not sure how they hold up in the long run but they are way cheaper than borgeson. i would say as long as the moving parts got grease fittings that have been maintained you would likely only need a bushing kit to replace all the old and dry rotted bushings.
Old Jan 13, 2021 | 08:09 PM
Moparite's Avatar
Moparite
Not to mention like Moog has two of the same ball joints but with different boots with two different part #'s. Nothing wrong with picking and choosing what brands you want.
