1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Hello all I have a 88 d100 5.2 L V8. Currently the truck will not start, It turns over and and sputter for a second then I have replaced the fuel injectors with no luck. When I pull the fuel supply line of the throttle body and turn the ignition to on it will shoot out some gas then stop. Any suggestions on where to start trouble shooting? Could the fuel pressure regulator be bad? Any thoughts will be greatly appreciated.
The fuel pressure should be 14.5 psi. The computer tells the injectors when to fire, I would check the wiring connections between the injectors and the computer.
