1978 D150 Stalling issue.
Old 12-11-2021, 09:13 PM
Skatulaki's Avatar
Skatulaki
Skatulaki is offline
Gotta be one or the other, loss of fuel, or loss of fire.
  #22
Old 12-12-2021, 09:25 AM
Moparite's Avatar
Moparite
Moparite is offline
I parked the truck and went to put the air cleaner back on and noticed the fuel filter was almost completely empty.
Could be vapor lock or possible weak pump. I had a fairly new pump partially brake the spring inside. It would run the motor but not produce enough flow. If it's an original pump might want to replace it. If you mount the fuel filter vertically it will allow the air to go up and not get trapped.
  #23
Old 12-12-2021, 09:21 PM
Joel142's Avatar
Joel142
Joel142 is offline
I went over all the wires and made sure everything was tight and the grounds were good, then went out at night and ran it to see if I saw any spark jumping around and nothing.
Then I went under the truck and traced the fuel lines, and they look fine not rotted and no signs of any leaks. Today I went onto Advanced Auto parts website and saw they only wanted $24 for a new fuel pump, so I figured worth a try. I put it on and ran they truck around the yard for 45 minutes and no stalling. SUCCESS!!!!
I can’t thank you all enough for all your advice and input.
Happy Holidays
Joel
  #24
Old 12-13-2021, 06:58 AM
ol' grouch's Avatar
ol' grouch
ol' grouch is offline
Glad you found the issue. If the pump is fairly new and not NOS, it ought to be the last you have to deal with the problem. Older ones sitting on the shelf don't like the E-10 gasoline most of us get.
  #25
Old 12-13-2021, 05:43 PM
volaredon's Avatar
volaredon
volaredon is offline
Your engine controller (the brain box) may be getting hot and failing. These used to be fairly easy to find at parts stores. It's just a plug and a couple of bolts. If you're still running the lean burn, I'd convert to regular electronic ignition.
no lean burn on trucks yet in 78.
  #26
Old 12-14-2021, 02:03 PM
Joel142's Avatar
Joel142
Joel142 is offline
I sure hope it's the last time i will have to deal with that issue, I ran the truck around the yard today just to make sure and she rans perfect no stalling, I hope to get through a few more winters with her, while I try to find a nicer dodge pickup to put the plow on.
Quick Reply: 1978 D150 Stalling issue.
