Distributor condenser
Question is why are you still using a points distributor? Come out of the archaic days and upgrade to electronic ignition. Somebody probably put a distributor from the 60's/early 70's in it.They probably got rid of the lean burn system. If you still want to keep the points set up you need to find out what year the distributor is. You probably have something like . Upgrade to electronic ignition would be the better choice.
Unless someone swapped an old points distributor in, you don't have a condenser. I'm thinking your electronic ignition hall effect has failed. Rather than replace those, I usually will put a rebuilt distributor in it.
