88 with 93 30 gal sputter problems
Old Dec 20, 2021 | 09:38 AM
Maki's Avatar
Maki
it shouldn't matter which way the sending unit sits as long as you can hook everything up and the float arm has room to go up and down without hitting anythings. also sounds like you may have ordered the wrong sending unit if you need one with return line and it didn't have one. it should still do the job. i am cheap and just usually replace the pump/pickup screen. i don't replace the whole assembly unless the sending unit is acting up.
Wrong pump for my truck but not for the gas tank so I had to improvise to make it work. Also, I didn’t see any way to adjust the float or the pump in the tank. Did flip it so guess I’ll see next time I take the truck out
Old Dec 20, 2021 | 02:10 PM
crazzywolfie's Avatar
crazzywolfie
there is 4 screws. you loosen them and can slide the pump down. you want the fuel pickup touching the bottom of the tank.
