99 ford explorer 5.0 v8 into a v6 1st gen dodge ram
Old Jan 23, 2022 | 04:36 AM
whoisdrwho12's Avatar
whoisdrwho12
Default 99 ford explorer 5.0 v8 into a v6 1st gen dodge ram
What type of kit would I need and were would I find it
and are the Transmisson compatible how would I find it that out
Old Jan 23, 2022 | 07:52 AM
Moparite's Avatar
Moparite
Furd in a Dodge?
Do this instead!
Old Jan 23, 2022 | 03:49 PM
whoisdrwho12
Originally Posted by Moparite
Furd in a Dodge?
Do this instead!
that's not helpfull I don't have a Mangum engine laying around I do have a ford explorer with a perfect engine and a 1st Gen dodge with no engine see where I'm going with this don't want to acquire a new eninge
Old Jan 23, 2022 | 05:18 PM
You aren't going to find a kit. This is going to be completely custom. The ford motor won't bolt to dodge transmissions either, at least, not without an adapter, and I don't know of anyone that makes 'em. You will need the engine and trans, plus, all the electronics to make it run/shift/etc. Likely need the t-case as well, if it's a 4x4, and custom driveshaft(s)..... You are going to spend more dropping in the ford motor, than you would, if you just went out and bought a donor truck, for the engine/trans.
Old Jan 23, 2022 | 05:30 PM
whoisdrwho12
I planned on having to transfer everything from the explorer (the explorer is comple with a bad transmission) anyway so basically I have to weld new engine mounts and find a donor transmission for the explorer
im doing this just to see if I am capable
Old Jan 23, 2022 | 06:41 PM
BM9NBA2's Avatar
BM9NBA2
Booooooo you'd be better off with a 4bt swap that's way worth the time, effort, and money.
Old Jan 23, 2022 | 06:44 PM
whoisdrwho12
don't have one of those sitting in my driveway
Old Jan 23, 2022 | 06:46 PM
BM9NBA2's Avatar
BM9NBA2
well sell that explorer with the trash.0 and get yourself a nice setup
Old Jan 23, 2022 | 07:38 PM
Even if you sell the explorer for scrap, and do the 4bt swap, you will still spend less.
Old Jan 24, 2022 | 01:31 PM
u2slow's Avatar
u2slow
A 5.0L and T5 manual trans is a fun combo in just about anything. No way I'd screw around with an electronic auto though - would take the fun right out of it.
