1988 W100 Spraying Fuel
My truck will start if I soak the air cleaner with gas.
I replaced both injectors, the fuel pressure regulator and the fuel filter at the tank.
The truck runs but does not seem to be drawing fuel.
I took the air cleaner off and witnessed the truck start right up then die with a glorious spray of gas bouncing up out of the engine.
I assume the injectors are getting gas, hence the spray but that gas is not getting into the engine.
It sounds like the gas runs out of the injectors when I turn the ignition on, makes a puddle and then sprays up and out when the engine coughs.
I am stumped.
I am stumped.
